Staple Finisher-L1/Booklet Finisher-L1 (Optional)
08JK-0LY
If a paper jam occurs in the Staple Finisher-L1 or Booklet Finisher-L1, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Staple Finisher-L1, Booklet Finisher-L1, Document Insertion/Folding Unit-G1, and Document Insertion Unit-J1 are optional products.
