e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products (imageRUNNER ADVANCE C9280 PRO/C9270 PRO)
Optional Products (imageRUNNER ADVANCE C7270/C7260)
Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Right Cover of the Machine
Right Cover of the Machine (When the Multi-drawer Paper Deck-A1 is attached)
Left Cover of the Machine
Left Cover of the Machine (When the Buffer Pass Unit-J1 is attached)
Fixing Transport Unit
Paper Sources
Multi-purpose Tray
Paper Drawers 3 and 4
Paper Drawers (Right/Left)
Paper Deck Unit-C1/POD Deck Lite-A1 (Optional)
Front Cover of the Multi-drawer Paper Deck-A1 (Optional)
Paper Decks of the Multi-drawer Paper Deck-A1 (Optional)
Duplex Color Image Reader Unit-F1 (Optional)
Buffer Pass Unit-J1
Document Insertion Unit-H1 (Optional)
Professional Puncher Integration Unit-B1 (Optional)
Paper Folding Unit-G1 (Optional)
Staple Finisher-K1 (Optional)
Booklet Finisher-K1 (Optional)
Inside the Front Cover
Saddle Stitcher Unit
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1 (Optional)
Insertion Unit
Inside the Insertion Unit
Folding Unit
External 2/3 Hole Puncher-A1 (Optional)
Staple Finisher-L1/Booklet Finisher-L1 (Optional)
Inside the Top Cover
Output Area
Front Cover of the Booklet Finisher-L1
Saddle Stitcher Unit of the Booklet Finisher-L1
Reducing the Frequency of Paper Jams
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Stapler Unit of the Staple Finisher-K1/Booklet Finisher-K1
Saddle Stitcher Unit of the Booklet Finisher-K1
If Memory Becomes Full During Scanning
If OCR (Text Searchable) Performs Inadequately
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network/Security
MEAP
User Setting Information Management
List of Error Codes without Messages
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Software
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Problem Solving
Clearing Paper Jams
08JK-0KS
Paper jams may occur in the following parts of the machine. See the applicable section to clear the paper jam.
Multi-purpose Tray
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
Buffer Pass Unit-J1
17.
(Booklet Finisher-K1 (Optional))
18.
19.
20.
Insertion Unit
21.
22.
Folding Unit
23.
24.
25.
26.
27.
Output Area
Back to Top
