0R9W-042
You can manually print the User Data List whenever necessary.
Items that have been changed from their default settings are printed with an asterisk (*) next to them. Use the asterisk to check which items have been changed from their default settings.
An optional product is required to use the Fax function. For information on the optional products required to use the Fax function, see
"Optional Products Required for Each Function."
The following types of User Data Lists are available:
User Data List (Communications)
Prints settings (except fax related settings) in [Send]/[Receive/Forward] in [Function Settings] (Settings/Registration), and the registered destination settings.
Prints fax related settings in [Send]/[Receive/Forward] in [Function Settings] (Settings/Registration).
Prints information related to the network stored in [Preferences] (Settings/Registration).
Some items that have been changed from their default settings have an asterisk (*) next to the item above them.
Press
Press [Function Settings] → [Send] or [Receive/Forward] → [Output Report].
Press [TX/RX User Data List].
4.
Press [Yes].
Press
Press [Fax User Data List].
4.
Press [Yes].
Press
Press [Preferences] → [Network] → [Output Report].
Press [Yes].
The following items in User Data List (Network) are automatically generated from unique information of the machine by default and when the settings are initialized, and have an asterisk (*) next to them.
IPv4 Host Name
IPv6 Host Name
mDNS Name (mDNS Settings)
Service Name (AppleTalk Settings)
Current Transmission Speed (Ethernet Driver Settings)
