Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Printing Reports » FAX RX REPORT
FAX RX REPORT
0R9W-03R
A Fax RX Report can be printed automatically after documents are received, and you can also set the machine to print a Fax RX Report only when a reception error occurs.
An optional product is required to use the Fax function. For information on the optional products required to use the Fax function, see "Optional Products Required for Each Function."
The items printed for the report and a description of each item are indicated below.
JOB NO.
The four digit number, that is automatically assigned when the document is accepted for receiving, is printed.
DESTINATION ADDRESS
The fax number of the sender is printed, up to the first 47 digits.
SUBADDRESS
A subaddress is printed, if specified. The password is not printed to maintain security.
DESTINATION ID
The DESTINATION ID of the sender is printed.
ST. TIME
The date and time (in 24-hour notation) at which the document started to be received are printed.
TX/RX TIME
The time taken (in minutes and seconds) to receive the document from start to finish is printed.
PGS.
The number of pages that were received is printed.
RESULT
Prints "OK" or "NG."
If a receive job is canceled, <STOP> is printed.
OK:
Reception was completed successfully.
NG:
Reception failed. The error code is also printed next to "NG."
Printing the Fax RX Report
Press [Function Settings] → [Receive/Forward] → [Fax Settings].
Press [Fax RX Report].
4.
Press [For Error Only] or [On].
Press [Off] if you do not want to print the report.
5.
Press [OK].
