Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Screens Displayed on the Touch Panel Display
0R9W-00Y
After the machine's power is turned ON, a screen similar to the following (the Main Menu screen) appears on the touch panel display. You can display the screens for each function from the function keys displayed on the Main Menu screen.
Main Menu Screen
Function Screen (Copy)
Display the Main Menu screen. If the Main Menu screen is not displayed when using a function, it is necessary to press [Main Menu] before operating the machine. If you want to display all functions, press [Show All].
You can specify the display settings for the Main Menu screen and the function screens.
If you are logged in using a login service, [Log Out] is displayed.
4.
An icon indicating that a paper or staple jam has occurred, or an icon indicating that a USB device is attached, is displayed.
5.
The progress of jobs and copy operations, and the status of devices and consumables are displayed here. Also, depending on the login service you are using, the Department ID or user name can be displayed.
6.
Press to check the status of jobs or to cancel print jobs. Also, you can check the status of the machine such as the amount of paper remaining in the paper source. (See "Status Monitor/Cancel.")
7.
You can display up to four shortcut keys for functions. [Dest./Fwd. Settings] is set for the fourth shortcut key by default. (See "Setting Shortcut Buttons.")
8.
Press to display functions registered in the Quick Menu. (See "Quick Menu.")
Press the touch panel display buttons gently with your fingers or the edit pen. Do not use an object with a sharp end, such as a mechanical pencil or ballpoint pen. Doing so may scratch the surface of the touch panel display or break it.
Before using the touch panel display, peel off the protective film from the display.
After the machine's power is turned ON, you can change the default screen displayed at startup. For information on the available screens that can be set to display after the machine starts up, see "Default Screen after Startup/Restoration."
For information on the Quick Menu screen settings, see "Using the Quick Menu from the Machine."
The settings that can be specified may differ, depending on the user's privileges.
