Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Other Useful Functions
0R9W-01Y
This section describes other useful functions of the machine.
Auto Drawer Switching
If a paper drawer runs out of paper while printing, the machine automatically locates another paper drawer loaded with the same size paper, and begins feeding paper from that paper drawer.
You can set whether a paper drawer is subject to automatic paper drawer switching for each function. The default setting is 'Off' for the multi-purpose tray, and 'On' for the other paper drawers. (See "Enabling Paper Drawer Auto Selection.")
Auto Reset
If the machine is not used for a specified period of time after the last print job or key operation is performed, the job settings are canceled and touch panel display automatically returns to the screen set in [Default Screen after Startup/Restoration].
You can set the Auto Reset Time from 0 to 50 seconds in 10 second increments and 1 to 9 minutes in one minute increments. The default setting is '2' minutes. (See "Auto Reset Time.")
Number of Copies/Job Duration Status Display
If you set [No. of Copies/Job Duration Status] to 'On' in [Preferences] (Settings/Registration), the number of copies specified and the approximate time before the current job completes are displayed on the bottom line of the touch panel display.
The approximate time does not appear when the wait time is less than one minute. (See "Number of Copies/Wait Time Status Display.")
Paper Supply Indicator
The paper supply indicator shows the remaining amount of paper in each paper drawer on the Paper Select screen, and on the screen that appears when paper in a paper drawer has run out while printing.
The Paper Select Screen
*Paper Supply Indicator
Display When Paper Has Run Out
There are four different paper supply indicators, as shown below:
Display
Remaining Paper
Paper drawer is approximately 50% to 100% full.
Paper drawer is approximately 10% to 50% full.
Paper drawer is less than 10% full.
Paper drawer is empty.
Auto Orientation
Setting this mode enables the machine to use information such as the size of the original and the zoom ratio to determine the most suitable orientation for the specified paper size. The machine then automatically rotates the image if necessary.
If the image does not fit onto the paper after it is rotated, the machine will not rotate the image, and will print it as is, with part of the image cut off.
Destination/Forwarding Settings
You can register/edit destinations and specify forwarding settings from [Dest./Fwd. Settings] displayed on the main menu screen or from a shortcut button. (See "Setting Shortcut Buttons.")
Shortcut Button
Main Menu Screen
For details on the procedure for setting destinations/forwarding, see the following.
Register Destinations (See "Register Destinations.")
Register One-Touch (See "Registering One-Touch Buttons.")
Forwarding Settings (See "Storing Forwarding Settings.")
