Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Printing Reports
Printing Reports
0R9W-038
You can print various types of reports from the machine, to check settings and logs. Some reports are printed automatically, and some are printed manually. You can also set to print some reports automatically only when an error occurs.
You can print the following types of reports from the machine.
Counter Report
The Counter Report contains the number of pages copied/printed and the number of completed send jobs.
PAGE COUNT LIST
The Page Count List contains the Copy, Scan, and Printer counter information for each department.
PRINT LOG LIST
The Print Log List contains the print job history.
The Device Information Distribution Destination List contains information about registered distribution destinations.
This report is a list which enables you to check the send, receive, and access logs for device information.
SEND JOB LIST
This report is used to check a list of jobs before sending or after sending.
TX REPORT
This report is used to check whether documents were sent correctly to their intended destinations.
FAX MULTI TX REPORT
This report is used to check whether documents were sent successfully to the intended destinations when a sequential broadcast transmission was performed.
FAX RX REPORT
This report is used to check whether documents have been successfully received.
This report is used to check whether documents have been successfully received in Confidential Fax Inboxes.
This report is a list which enables you to check the results of all sending and receiving.
This report is a list which enables you to check the results of all sending and receiving transactions for the Fax function.
You can print the contents of the forwarding settings that have been specified.
You can print the registered LDAP server settings.
ADDRESS LISTS
This report enables you to print and check the contents of the Address List (Address Lists 1 to 10 or one-touch buttons) in [Management Settings] (Settings/Registration).
Store Log Report
You can print the history of file storage.
User Data List
Prints the registration information for Settings/Registration. This is useful for checking settings details.
System Information
You can print the information for the applications installed in MEAP and some system application information.
Mail Box File List
You can print the information for the files stored in a mail box.
IPSec Policy List
You can print a list of the IPSec policies and confirm their priorities.
Printer Report
You can print a configuration page and font list for the PCL or PS Printer.
This report is used to check whether all the data and settings have been successfully initialized.
The following conditions must be met for a report to be printed:
There is a paper drawer with [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration) set to 'On'.
One of the following paper sizes is loaded in that paper drawer:
11" x 17"
LGL
LTR
LTRR
The loaded paper is one of the following types:
Plain 1 (17 lb bond to 20 lb bond (64 to 75 g/m2))
Plain 2 (21 lb bond to 24 lb bond (76 to 90 g/m2))
Plain 3 (25 lb bond to 28 lb bond (91 to 105 g/m2))
Recycled 1 (17 lb bond to 20 lb bond (64 to 75 g/m2))
Recycled 2 (21 lb bond to 24 lb bond (76 to 90 g/m2))
Recycled 3 (25 lb bond to 28 lb bond (91 to 105 g/m2))
Thin (14 lb bond (52 to 63 g/m2))
Color (17 lb bond to 21 lb bond (64 to 82 g/m2))
However, if [Consider Paper Type] for Copy is set to 'On' in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration), paper is not fed from paper drawers with color paper specified.
