Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Adding New Functions » Logging In to SMS
Logging In to SMS
0R9W-029
Log in to SMS from the Remote UI portal page.
There are two methods for logging in; performing authentication with the user name and password of an administrator, and performing authentication with the SMS password.
You can switch the login method on the [System Application Management] page in [System Management]. (See "Switching to the Login Method for Using the SMS Password.")
By default, you can log in using the user name and password of the Administrator, because User Authentication is enabled.
If DepartmentID Authentication is set as the login service, you cannot log in to SMS with the user name and password of the machine.
Multiple users cannot log in to SMS at the same time.
You cannot connect to the machine via a proxy server. In the proxy server settings of your Web browser, add the IP address of the machine to the [Exceptions] (addresses that do not use a proxy) list. (As these settings differ depending on the network environment, contact the administrator for the network you are using.)
Only enter characters in your Web browser that can also be entered from the touch panel display of the machine. Otherwise, the characters you enter from your Web browser may not be displayed or recognized correctly on the touch panel display.
When you finish using SMS, make sure you log out. If you close the Web browser without logging out, SMS becomes temporarily inaccessible.
