Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Adding New Functions » Installing System Options/MEAP Applications (Distribution)
0R9W-021
If the machine is connected to an external network, you can install system options/MEAP applications via a distribution server.
This operation can only be performed by a user with the required privileges. For information on the types of administrator, see "How User Authentication Works."
Prepare the license access number certificate that was included in the package.
For instructions on connecting to an external network, see "Network Environment Setup Procedures."
To check whether the machine can communicate properly with the distribution server, perform a communication test before installation, as necessary. (See "Performing a Communication Test With the Distribution Server.")
Installing a System Option/MEAP Application Using the Touch Panel Display
You can install system options/MEAP applications in the machine using the touch panel display.
Press [Management Settings] → [License/Other] → [Register/Update Software].
Press [Install Applications/Options] → [License Access Number].
4.
Enter the four digit License Access Number → press [OK].
Repeat this step four times to enter a total of 16 digits for the License Access Number.
5.
Press [Start].
6.
Select a system option/MEAP application → press [Install].
[Do Not Start]: Press to not start the MEAP application when installing it.
If the license agreement screen is displayed, confirm the information → press [Accept].
System options become active after you restart the machine. Restart the machine after installation.
If you press [Do Not Start] when installing a MEAP application, it is necessary to start the MEAP application before using it. (See "Starting/Stopping Applications.")
You can select multiple system options/MEAP applications, however, you cannot select different versions of a product at the same time.
Installing System Options/MEAP Applications Using the Remote UI
You can install system options/MEAP applications in the machine using the Remote UI.
From the portal page of the Remote UI, click [Settings/Registration] → [License/Other] → [Register/Update Software].
Click [Distributed Installation].
Enter the license access number → click [Next >].
If an incorrect license access number is entered, an error page appears.
4.
Select a system option/MEAP application → click [Start Installation].
Operations after installation:
[Start]: Starts the installed MEAP application.
[Stop]: Stops the installed MEAP application.
If the license agreement screen is displayed, confirm the information → click [Accept].
Click [To Distributed Installation] to return to the distribution installation page.
If you press [Stop] when installing a MEAP application, it is necessary to start the MEAP application before using it. (See "Starting/Stopping Applications.")
The maximum number of MEAP applications that can be installed is 19.
The maximum amount of hard disk space that MEAP applications can use is approximately 4 GB.
There may be other system requirements for installation, depending on the MEAP application. For more information, see the manual provided with each MEAP application.
Depending on the installed system option/MEAP application, you can download the manual or related software for the system option/MEAP application from the URL displayed on the screen after installation.
