Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Printing Reports » FAX MULTI TX REPORT
FAX MULTI TX REPORT
0R9W-03L
If a sequential broadcast transmission is performed when [Fax TX Report] is set to 'On', a Fax Multi TX Report is automatically printed. (See "FAX TX REPORT/FAX ERROR TX REPORT.")
You can also print a Fax Multi TX Report with an image of the sent original attached to it.
An optional product is required to use the Fax function. For information on the optional products required to use the Fax function, see "Optional Products Required for Each Function."
The items printed for the report and a description of each item are indicated below.
JOB NO.
The four digit number, that is automatically assigned when the document is accepted for sending, is printed.
DEPT. ID
If Department ID Management is set, the Department ID is printed.
PGS.
The number of pages that were sent is printed.
TX INCOMPLETE
If a transmission is incomplete, the fax number and the name of the destination are printed.
TRANSACTION OK
The fax number and the name of the destination of a completed transmission are printed.
ERROR
If a transmission error occurs, the fax number and the name of the destination are printed.
If an image is not attached, <TX IMAGE SET NOT TO DISPLAY> appears below the title.
If it is unclear whether the document was successfully received at the destination, "---" is printed.
