Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Checking the Counter and Controller Version
0R9W-01S
You can check the copy and print page counts, and the copy and print page counts for each MEAP application.
You can also check the version of the controller and the IP address of the machine, etc.
You can display/hide the IP address in [IP Address Display Settings] in [Preferences] (Settings/Registration).
Press (Counter Check) on the control panel.
Each item of the counter is counted under the following conditions.
Depending on the settings performed by the local authorized Canon dealer, the following counter may not be displayed or counter not listed below may be displayed.
Number
Counter Name
Counted Items
Counted Number per One Printed/Scanned Sheet*1
Job Type
Color Mode
Size
Number of Printed/Scanned Sides
Large*2
Small*3
One-Sided
Two-Sided
101
Total 1
All Print Jobs
Full Color/Single Color/Two Colors/Black
1
1
1
2
102
Total 2
All Print Jobs
2
1
1
2
108
Total (Black 1)
All Print Jobs
Black
1
1
1
2
109
Total (Black 2)
All Print Jobs
Black
2
1
1
2
110
Total (Single Color/Large)
All Print Jobs
1
0
1
2
111
Total (Single Color/Small)
All Print Jobs
0
1
1
2
112
Total (Black/Large)
All Print Jobs
Black
1
0
1
2
113
Total (Black/Small)
All Print Jobs
Black
0
1
1
2
114
Total 1 (2-Sided)
All Print Jobs
1
1
0
1
118
Total (Single Color 1)
All Print Jobs
1
1
1
2
122
Total (Full Color + Single Color/Large)
All Print Jobs
1
0
1
2
123
Total (Full Color + Single Color/Small)
All Print Jobs
0
1
1
2
133
Total A (Black 2)
All Print Jobs (Except Copy Jobs)
Black
2
1
1
2
148
Total A (Full Color + Single Color 2)
2
1
1
2
149
Total A (Full Color + Single Color 1)
1
1
1
2
222
Copy (Black 2)
Copy Jobs
Black
2
1
1
2
229
Copy (Full Color + Single Color/Large)
Copy Jobs
1
0
1
2
230
Copy (Full Color + Single Color/Small)
Copy Jobs
0
1
1
2
231
Copy (Full Color + Single Color/2)
Copy Jobs
2
1
1
2
232
Copy (Full Color + Single Color/1)
Copy Jobs
1
1
1
2
301
Print
(Total 1)
All Print Jobs
(Except Copy and Receive Print Jobs)
1
1
1
2
321
Print (Full Color + Single Color/Large)
All Print Jobs
1
0
1
2
322
Print (Full Color + Single Color/Small)
All Print Jobs
0
1
1
2
324
Print (Full Color + Single Color/1)
All Print Jobs
1
1
1
2
401
Copy + Print (Full Color/Large)
All Print Jobs
(Except Receive Print Jobs)
Full Color
1
0
1
2
402
Copy + Print (Full Color/Small)
All Print Jobs
(Except Receive
Print Jobs)
Full Color
0
1
1
2
501
Scan (Total 1)
All Scan Jobs
Color/Black
1
1
1
2
*1 The counted number per one printed/scanned sheet for each item on the counter is as follows:
"number in the Size (Large or Small) column" x "number in the Number of Scanned/Printed Sides (One-Sided or Two-Sided) column"
Example: For large, double-sided print, the number added to <102 Total 2> is 2 x 2 = 4.
*2 Large: Standard size larger than 11" x 17".
*3 Small: Standard size smaller than LTR.
Check the following.
To check the counter report:
To check the Send/Fax counter:
To check the MEAP counter:
To check the controller version or installed options:
Press [Print List].
Press [Yes].
Press [Check Send/Fax Counter].
[Check Send/Fax Counter] is displayed only if the fax function is available for use.
If the fax function is not available for use, [Check Send Counter] is displayed.
For information on the optional products required to use the fax function, see "Optional Products Required for Each Function."
For each item of the Send/Fax Counter, the number of scanned sides are counted under the following conditions.
: Counted
-: Not counted
Counter Name
Types of Destination Used for Counting*1
Color Mode
E-Mail
File
Fax
I-Fax
Black Scan
(Total 1)
Counted when the color mode is Black-and-White or Grayscale.
Black Scan 1
Black Scan 2
Black Scan 3
Black Scan 4
Color Scan
(Total 1)
Counted when the color mode is Full Color.
Color Scan 1
Color Scan 2
Color Scan 3
Color Scan 4
*1: If there is more than one corresponding destination, the number of scanned sheets is counted.
Press [OK].
Press [Check MEAP Counter].
Select the desired application from the <Application Name:> drop-down list.
To check the version information of an application, the MEAP Contents version information, etc., press [Version Information].
Press [OK].
Press [Chk. Device Config.].
Press [OK].
Press [OK].
