Displaying the Installation Log
0R9W-024
You can display the installation/update log from the touch panel display or the Remote UI.
This operation can only be performed by a user with the required privileges. For information on the types of administrator, see "Setting Administrators."
Using the Touch Panel Display
You can check the installation log for system options/MEAP applications using the touch panel display.
Press
(Settings/Registration).
Press [Management Settings] → [License/Other] → [Register/Update Software].
Press [Software Management Settings] → [Select Log Display] → [Display Update Logs].
You can check the installation log for system options/MEAP applications using the Remote UI.
From the portal page of the Remote UI, click [Settings/Registration] → [License/Other] → [Register/Update Software].
Click [Display Logs/Communication Test].
Select [Update Logs] from the Log View drop-down list → click [Switch].
