Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Adding New Functions » Logging In to SMS » Logging In with the SMS Password
0R9W-02C
The SMS password is used when logging in to SMS in the following cases:
When User Authentication is used as the login service and Remote Login Service Authentication is stopped
When DepartmentID Authentication is used as the login service
This password is to prevent unauthorized operation of the machine. Do not inform anyone other than the administrator of this password.
In order to prevent erroneous usage, change the password to one that only the administrator knows (when you begin using it). If you want to change the password, see "Changing the Password."
Make sure that you do not forget your password. If you forgot the password, you will become unable to log in to SMS using the login method where authentication is performed using the SMS password.
The default password is "MeapSmsLogin" (case sensitive).
Click [Service Management Service] on the Remote UI portal page.
Enter the password → click [Log In].
If SMS is idle for longer than five minutes, it will timeout and you are automatically logged out. If this happens, log in again from the [Login] page. The estimated time until a timeout occurs is displayed on the top right of the screen.
If you do not log in within five minutes of displaying the [Login] page, you cannot log in even if you enter the correct password. Re-enter the password according to the message displayed on the screen.
If an incorrect password is entered, a screen prompting you to enter the password again is displayed. To initialize the password, click [Browse…] on this screen → select a license switch file → click [Initialize]. For information on license switch files, contact your local authorized Canon dealer.
