Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Adding New Functions » Overview of SMS (Service Management Service)
0R9W-026
SMS (Service Management Service) is software used to manage MEAP applications. It enables you to install MEAP application, start/stop installed applications, and switch the login service, etc. SMS is accessed from the Remote UI.
Do not use the browser's [Back] button. If you use [Back] to change pages, SMS may not operate correctly.
Confirming the Machine's MEAP Application Status
The following screen is displayed when you press [Service Management Service] on the Remote UI portal page.
[MEAP Application Management]
The status, etc. of the applications installed in the machine is displayed.
[Install MEAP Application]
You can install MEAP applications.
[Enhanced System Application Management]
You can switch and delete system applications installed on the machine, and add new applications to the machine.
[System Application Management]
You can check and edit operations for the system applications installed on the machine.
[System Information]
The information, etc. of the platform and system applications installed in the machine is displayed.
[MEAP Application Information]
Detailed information for the applications installed in the machine is displayed.
[Check License]
You can check the current license status.
[Change Password]
You can change the password.
[MEAP Application Setting Information Management]
You can delete user data and MEAP application data being managed by the machine.
[MEAP Application Log Management]
You can download and delete MEAP application log data.
[<< To Register/Update Software]
The page for installing applications and updating firmware is displayed.
In the following cases, a screen for entering the password for logging in to SMS is displayed when you click [Service Management Service].
When User Authentication is used as the login service and Remote Login Service Authentication is stopped
When DepartmentID Authentication is used as the login service
Installing and Uninstalling MEAP Applications on the Machine
You can install and uninstall MEAP applications that correspond to the machine. (See "Installing Applications" and "Uninstalling Applications.")
Updating Installed MEAP Applications and License Files
You can reinstall and update MEAP applications and license files if they have expired. (See "Managing Application Licenses.")
