Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Volume and Tone Settings
0R9W-01L
Pressing  (Volume Settings) on the control panel enables you to adjust the fax sending/receiving alarm volume and transmission volume. You can also set various tones to sound according to the operations performed or status of the device.
Adjusting the Alarm and Monitor Volume
You can set the volume for the alarm and monitor tones that this machine sounds during a fax transmission.
This mode can be set when the Fax function is available for use. For information on the optional products required to use the Fax function, see "Optional Products Required for Each Function."
Press  (Volume Settings) on the control panel.
Press  or → set <Alarm Volume> and <Monitor Volume> → press [OK].
You can set the volume to any level on a scale of 0 to 9.
If you set the volume all the way to the left, the volume is muted and no tone will sound.
Setting the Operation and Device Status Tones
You can set whether to sound the following audible tones. The tones below sound at the following times:
[Entry Tone]:
When pressing keys on the control panel, keys on the touch panel display, or keys on a USB keyboard. When turning ON the main power of the machine if you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration). (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
[Invalid Entry Tone]:
When you press an invalid key on the control panel or touch panel display, or when the maximum number of characters is exceeded.
[Restock Supplies Tone]:
When the toner cartridge needs to be replaced.
[Sleep Mode Tone]:
When the machine goes in the Sleep mode. When turning OFF the main power of the machine if you set [Quick Startup Settings for Main Power] to 'On' in [Preferences] (Settings/Registration). (Depending on the situations, the machine does not startup quickly and the tone does not sound.)
[Error Tone]:
When a malfunction occurs (e.g., paper jam or operational error).
[Job Done Tone]:
After a job completes.
[Memory RX/TX End Tone]:
When Fax Memory Lock sending/receiving completes without an error.
[Memory RX/TX Err. Tone]:
When Fax Memory Lock sending/receiving completes with an error.
[Memory RX/TX End Tone] and [Memory RX/TX Err. Tone] can be set when the Fax function is available for use. For information on the optional products required to use the Fax function, see "Optional Products Required for Each Function."
Press [Audible Tones].
If the fax board is not installed, this step is not necessary. Proceed to step 3.
Specify each setting → press [Next] → [OK].
The alarm tone sounds when sending or receiving is canceled or when printing a received fax is completed.
The monitor tone sounds when it connects to the recipient's fax machine.
The ring count you set may change according to the ring signal, if you are connected to a PBX, etc.
