Top » Remote UI » System Requirements
System Requirements
0R9W-1SS
The system requirements for the Remote UI are as follows:
Windows
OS (Operating System)
Windows Vista SP2
Windows 7 SP1
Windows 8
Windows 8.1
Web Browser
Internet Explorer 8, or later
Macintosh
Mac OS X 10.7 Lion, or later
Web Browser
Safari 5.1, or later
Available Web browsers may be limited depending on the login service you are using. For instructions on how to use the login services, see "Other Login Services."
The appearance of the Remote UI screens may vary, depending on the type and version of the Web browser that you are using.
This machine is compliant with IPv6 addresses. To access IPv6 addresses, your environment must be compliant with IPv6.
Cannot be used with the Modern UI Edition of Windows 8.
No Web server or software other than that described above is required. (There is a Web server inside the machine.)
