e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
Authentication
Security
Practical Workflows
How to Use This Manual
Expand all
Collapse all
Category Top
Overview of This Function
Using the Quick Menu from the Machine
Keys on the Quick Menu Screen
Registering a Personal Button/Shared Button
Recalling a Personal Button/Shared Button
Editing a Personal Button/Shared Button
Changing the Size of Buttons
Specifying the Wallpaper Settings
Restricting Access to the Quick Menu
Importing/Exporting the Personal Buttons/Shared Buttons
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
Authentication
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Quick Menu
0R9W-196
This section describes how to use the Quick Menu from the touch panel display of the machine.
You can restrict the use of the Personal Button/Shared Button. For information, see
"Restricting Access to the Quick Menu."
Back to Top
