e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Specifying Authentication Method for Rights Management Server
Network Security
IEEE 802.1X Authentication Settings
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Setting the Key Pair Used With SSL Encrypted Communications
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
IPSec Settings
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Checking a Device Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
Top » Security » Specifying Management Settings for the Hard Disk » Completely Erasing Unnecessary Data from the Hard Disk
0S9Y-1J9
You can completely erase unnecessary or previously deleted data from the hard disk. You can select the mode and timing for erasing data from the hard disk.
The following data is completely erased from the hard disk:
Image temporarily data created when scanning
Remaining data after the files in the Mail Box are deleted
Spooled data
Remaining data after the files in the Fax/I-Fax Inbox (Confidential Fax Inbox/Memory RX Inbox) are deleted
Sent and received I-fax data
Data temporarily stored as print data
These settings can be specified when the Data Erase function is available for use. For information on the optional products required to use the Data Erase function, see "Optional Products Required for Each Function."
Setting the Hard Disk Data Complete Deletion
Press [Management Settings] → [Data Management] → [HDD Data Complete Deletion].
Press [Hard Disk Data Complete Deletion].
4.
Press [On] → [OK].
If you do not want to completely delete hard disk data, press [Off].
Setting the Timing of Deletion
Press [Timing of Deletion].
4.
Select the deletion timing → press [OK].
Details of each item are shown below:
[During Job]:
Overwrites and erases the data for each page as it is output.
[After Job]:
Overwrites and erases the data after all pages have been output.
Setting the Deletion Mode
You can set the Deletion mode and how many times to erase the data.
Press [Overwrite Method for Deletion Mode] → select the deletion mode → press [OK].
[Once with 0 (Null) Data]:
Overwrite the data once with 0 (null) data.
[Once with Random Data]:
Overwrite the data once with random data.
[3 Times with Random Data]:
Overwrite the data three times with random data.
[DoD Standard]:
Overwrite the data three times. The first time is with a fixed value, the second time with a complement of the fixed value, and the third time is with random data.
As you increase the number of times the data is erased, the performance of the machine when processing jobs may degrade.
You cannot use the machine while data is being erased from the hard disk. It may also take some time until the machine becomes ready to scan once the data is completely erased.
The performance of the machine may degrade when processing jobs.
