Setting the Control Panel Display
You can specify the control panel display settings.
Restricting Access to the Status Monitor/Cancel Screen
If you are using Department ID Management, you can restrict access to the Status Monitor/Cancel screen.
Press
(Settings/Registration).
Press [Management Settings] → [Device Management] → [Display Job Status Before Authentication].
Press [On] → [OK].
If [Display Job Status Before Authentication] is set to 'Off':
: Displayed -: Not Displayed
The Status Monitor/Cancel Screen
[Job], [Paper]
[Toner/Other]
Before Logging In
After Logging In
Even if you set the Display Status Before Authentication mode to 'Off', access to the Status Monitor/Cancel screen is only restricted if Department ID Management is set.
Displaying Job Logs from the Status Monitor/Cancel Screen
You can set whether to display job logs from the Status Monitor/Cancel screen. For display information of the Status Monitor/Cancel screen, see
"Status Monitor/Cancel."
Press
Press [Management Settings] → [Device Management] → [Display Job Log].
Press [On] → [OK].
If you do not want to display job logs, press [Off] → set the items for <Retrieve Job Log with Management Software> → press [OK].
Press [Allow] to allow the collection of job logs using management software.
Restricting Changes to Auto Clear Settings
If you set this mode to 'On', general users become unable to operate the following functions:
Press
Press [Preferences] → [Timer/Energy Settings] → [Restrict Auto Reset Time].
Press [On] → [OK].
If you do not want to restrict changes to Auto Clear settings, press [Off].
