Function
Optional Product Required
Operation of the Machine
Upright Control Panel-F1
Scanning Originals/Auto Document Feed
Duplex Color Image Reader Unit-K1
Adding High Capacity Feeding Area
POD Deck Lite-C1 or POD Deck-D1/Secondary POD Deck-D1
Adding Long Sheet Paper Feeding Area
LONG SHEET TRAY-A1
Adjusting the alignment of the front/back surface with the scanner
Adding High Capacity Outputting Area
High Capacity Stacker-H1
Collate/Group/Offset
Finisher-AN1, Saddle Finisher-AN2, or High Capacity Stacker-H1
Saddle Fold
Saddle Finisher-AN2
Corner Staple/Double Staple
Staple-N1
Finisher-AN1 or Saddle Finisher-AN2
Saddle Stitch Booklet
Staple-P1
Saddle Finisher-AN2
Hole Punch*
Puncher Unit-BT1/Puncher Unit-BS1
Loose Leaf 3-Hole Punch A4/LTR-B1, Loose Leaf 5-Hole Punch LTR-B1, Velo Bind 11-Hole Punch LTR-B1, Plastic Comb 19-Hole Punch LTR-B1, Twin Loop 21-Hole Punch LTR-B1, Twin Loop 32-Hole Punch LTR-B1, Color Coil 44-Hole Punch LTR-B1, Loose Leaf 2/4-Hole(8.5mm) Punch A4-B1, Loose Leaf 2/4-Hole(6.5mm) Punch A4-B1, Plastic Comb 21-Hole Punch A4-B1, Twin Loop 23/21-Hole(Round) Punch A4/LTR-B1, Twin Loop 34/32-Hole(Round) Punch A4/LTR-B1, Twin Loop 23-Hole(Square) Punch A4-B1, Twin Loop 34-Hole(Square) Punch A4-B1, Color Coil 47-Hole Punch A4-B1, High Durability Color Coil 44-Hole Punch LTR-B1, High Durability Loose Leaf 3-Hole Punch LTR-B1, High Durability Plastic Comb 19-Hole Punch LTR-B1, Velo Bind 12-Hole Punch A4-B1, or Loose Leaf 4-Hole Punch A4/LTR-B1
Multi Function Professional Puncher-A1
Crease
Crease die
Trim
Booklet Trimmer-D1
Saddle Finisher-AN2
Booklet Trimmer-D1 and Two-Knife Booklet Trimmer-A1
Additional Paper Type for Covers/Paper Insertion
Document Insertion Unit-N1
Z-Fold/Half Fold/C-Fold/Accordion Z-Fold/Double Parallel Fold
Paper Folding Unit-J1
Perfect Binding
Perfect Binder-E1
Closing the Feeder
ADF Access Handle
Machine Function
Required
Limitations
PS Print
imagePRESS Server
Sending functions
E-mail/I-fax transmission/Saving data to a file server
Color Universal Send Kit
Trace & Smooth PDF
Universal Send Advanced Feature Set
Searchable PDF/XPS
Office Open XML
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
HDD Data Encryption & Mirroring
HDD Data Encryption & Mirroring Kit
3.5inch/250GB HDD
Removable HDD Kit
Data Erase
Data Erase Kit
Voice Guidance
Voice Guidance Kit
To scan originals using the feeder or platen glass, the Duplex Color Image Reader Unit-K1 is necessary.
