e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Specifying Authentication Method for Rights Management Server
Network Security
IEEE 802.1X Authentication Settings
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Setting the Key Pair Used With SSL Encrypted Communications
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
IPSec Settings
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Checking a Device Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
Top » Security » Device Management » Specifying Device Information Delivery Settings » Setting Manual Delivery
0S9Y-1JR
You can set to manually deliver device information.
Press [Management Settings] → [Device Management] → [Device Information Distribution Settings].
Press [Manual Distribution] for <Transmitting Settings>.
4.
Select the device information to distribute → press [Next].
Press [On] for an item to deliver that data.
If you press [On] for <Settings/Registration Value>, set <Network Settings>. You can press [Include] → [OK] to deliver the network settings.
5.
Select the destination → press [Start Manual Distribution].
If you want to cancel the delivery, press [Cancel].
When delivery is complete, confirm the delivery results displayed in the 'Status' column on the Manual Delivery screen.
Even if you press [Cancel], delivery will not be canceled for machines to which information has already been delivered. Delivery to the next selected machine will be canceled.
6.
Press [OK] → [OK].
When delivering device information, the following machines will not update their information:
Machines which are processing a send job
Machines importing or exporting data via the Remote UI
The client machine which is receiving device information from another host machine will not update the address book.
The client machine which is performing a print job will not update the printer settings.
