Settings/Registration
System Manager
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[Edit Puncher Unit Die Name]
[Edit Primary Fixing Assembly Name]
[Edit Secondary Fixing Assembly Name]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
System Manager
[Adjust Image Quality]
[Auto Adjust Gradation]
[Register Paper to Adjust]
[Select Paper to Adjust]
[Select Method]
[Number of Sheets to Output for Test Page]
[Auto Correct Color Tone Settings]
[Register Correction Pattern]
[Dither Settings]
[Color Balance]
[Correct Color Cast]
[Correct White Gap]
[Correct Uneven Gloss for 2-Sided Printing]
[Correct Tail End Toner Application]
[Switch Fixing Temperature Adjustment Mode]
[Low Temperature Environment Mode]
[Correct Uneven Gloss]
[Adjust Drum Temperature]
[Special Smoothing]
[Maintenance]
[Refresh Fixing Roller]
[Fixing Roller Auto Refresh Level]
System Manager
[Common]
[Paper Output Settings]
[Normal/Rvrse. Order Output with Extrnl. Fin.]
[Face Up/Face Down Output with Extrnl. Fin.]
[Image Orient. When Output with Extrnl. Fin.]
[Print Settings]
[Copy Set Numbering Option Settings]
[Scan Settings]
[Auto Online]
[Auto Offline]
[Generate File]
[Rights Management Server Settings]
[Copy]
[Select Color Settings for Copy]
[Send]
[Common Settings]
[TX Report]
[Report with TX Image]
[Report with Color TX Image]
[Confirm SSL Certificate for WebDAV TX]
[Limit New Destination]
[Always Add Device Signature to Send]
[E-Mail/I-Fax Settings]
[Communication Settings]
[Confirm SSL Certificate for SMTP TX]
[Confirm SSL Certificate for POP RX]
[Maximum Data Size for Sending]
[Default Subject]
[Full Mode TX Timeout]
[Print MDN/DSN upon Receipt]
[Use Send via Server]
[Allow MDN Not via Server]
[Restrict TX Destination Domain]
[Auto Complete for Entering E-Mail Addresses]
[Receive/Forward]
[Common Settings]
[Interrupt and Print RX Jobs]
[Handle Files with Forwarding Errors]
[Forwarding Settings]
[Set Fax/I-Fax Inbox]
[Memory RX Inbox PIN]
[Use I-Fax Memory Lock]
[Memory Lock Start Time]
[Memory Lock End Time]
[Divided Data RX Timeout]
[Always Send Notice for RX Errors]
[Store/Access Files]
[Common Settings]
[Limit Box PIN to 7 Digits/Restrict Access]
[Mail Box Settings]
[Settings for All Mail Boxes]
[Box Security Settings]
System Manager
[Address Book PIN]
[Manage Address Book Access Numbers]
[Include Pswd. When Exporting Address Book]
[Register LDAP Server]
[Auto Search When Using LDAP Server]
[Register/Edit LDAP Search Conditions]
[Change Default LDAP Search Conditions]
[Acquire Remote Address Book]
[Make Remote Add. Book Open]
System Manager
[User Management]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Distribution Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Display Job Log]
[Save Audit Log]
[Store Key Operation Log]
[License/Other]
[Register License]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Register/Update Software]
[Data Management]
[HDD Data Complete Deletion]
[Initialize All Data/Settings]
[TPM Settings]
For information on the administrator, see "Administrator Settings."
