e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Specifying Authentication Method for Rights Management Server
Network Security
IEEE 802.1X Authentication Settings
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Setting the Key Pair Used With SSL Encrypted Communications
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
IPSec Settings
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Checking a Device Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
Top » Security » Preventing Information Leakage » Mail Box Settings » Specifying the Mail Box Security Settings
0S9Y-1J6
You can specify settings to improve the security of files stored in mail boxes.
Forcing Seven Digit Mail Box PINs
The PIN used when storing a file in a mail box can be set using at least one digit. If you set this function to 'On', users are forced to set a seven digit PIN.
Press [Function Settings] → [Store/Access Files] → [Common Settings].
Press [Limit Box PIN to 7 Digits/Restrict Access].
4.
Press [On] → [OK].
Select [Off] if you do not want to force users to set a seven digit mail box PIN.
Changes are only effective after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "Main Power and Energy Saver Key."
Allowing Changes to Print Settings upon Storing from the Printer Driver
In <Print When Storing from Printer Driver> in [Function Settings] (Settings/Registration), you can set whether to print a file when storing it in a mail box from a computer via the printer driver. (See "Mail Box Settings.") If you set this mode to 'Off', the settings for <Print When Storing from Printer Driver> cannot be changed.
Press [Function Settings] → [Store/Access Files] → [Mail Box Settings].
Press [Box Security Settings] → [Displ. Print When Storing from Printer Driver].
4.
Press [On] → [OK].
Select [Off] if you want to restrict changes to print settings upon storing from the printer driver.
Changes are only effective after you restart the machine. For instructions on restarting the machine, see "Main Power and Energy Saver Key."
If you registered a PIN of fewer than seven digits before you set this function to 'On', you can use the registered PIN. However, to ensure security, register the PIN again using seven digits.
If you set this function to 'On', users are forced to set seven digit PINs for the Memory RX Inbox and Confidential Fax Inboxes.
For instructions on setting a PIN for a mail box, see "Mail Box Settings."
For instructions on setting PINs for the Memory RX Inbox and Confidential Fax Inboxes, see "Specifying the I-Fax Inbox Settings."
