e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Specifying Authentication Method for Rights Management Server
Network Security
IEEE 802.1X Authentication Settings
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Setting the Key Pair Used With SSL Encrypted Communications
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
IPSec Settings
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Checking a Device Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
Top » Security » Device Management » Specifying Device Information Delivery Settings » Setting the Receiving Machine
0S9Y-1JS
If you want to restore device information to what it was before it was updated, only the data of the very last update is available to be restored.
While receiving and updating device information, the screen indicating that the settings are being updated appears. Operations on this machine cannot be performed until the update completes.
Restricting the Reception of Device Information
You can set whether to receive delivered device information from the different model machines, which have the Device Information Delivery Settings mode.
Press [Management Settings] → [Device Management] → [Device Information Distribution Settings].
Press [Restrict Receiving Device Information] for <Receiving Settings> → [On] → [OK].
If you do not want to restrict the reception of device information, press [Off].
4.
Press [OK].
Restoring Device Information
You can restore device information to what it was before it was updated. This is useful when you have accidentally updated the device information.
Press [Restore Data] for <Receiving Settings>.
4.
Select the information to restore → press [Start].
If you do not restore data for [Settings/Reg. Value] and [Address Book] at the same time, the settings in [URL Send Settings] for [Set Fax/I-Fax Inbox] and [Mail Box Settings] may be erased.
5.
Press [Yes].
6.
Press [OK] → [OK].
Restricting the Type of Information That Is Updated
You can set whether the machine receives and updates the delivered device information.
Press [Restrict Receiving for Each Function] for <Receiving Settings> → specify each setting → press [OK].
Press [On] for an item to set the machine to not receive and update that device information.
Before setting <Settings/Reg. Value>, <Dept. ID>, or <Address Book> to 'Off', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
4.
Press [OK].
Setting the Update Range of the Delivered Paper Information
You can set to register all received paper information or only the basic information of each paper type.
Basic information of paper includes <Name>, <Weight>, <Finish>, <Type>, <Color>, and <Adjust Creep Correction>.
If the received information of a paper type includes a value outside the setting range, the paper type may not be registered.
Press [Management Settings] → [Management Settings] → [Device Information Distribution Settings].
Press [Set Paper Information] for <Receiving Settings>
4.
Select [All] or [Basic Only] → press [OK].
[All]:
Registers all received paper information.
[Basic Only]:
Registers only the basic information of each paper type.
5.
Press [OK].
