Saving a Log of Key Operations
0S9Y-1K3
If you set this mode to 'On', you can save a log of the key operations performed by users.
By analyzing the stored logs, you can survey how the machine is being used.
This can be useful for resolving problems with your machine.
When the log is output, information such as passwords and PINs is output as masked characters. This can help prevent sensitive information from being leaked externally.
For information on interpreting and outputting saved logs, contact your local authorized Canon dealer.
Press
(Settings/Registration).
Press [Management Settings] → [Device Management] → [Store Key Operation Log].
Press [On] → [OK].
Select [Off] if you do not want to save the key operation log.
