e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Copy and Print Jobs without Entering a Department ID
Specifying Authentication Method for Rights Management Server
Network Security
IEEE 802.1X Authentication Settings
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Setting the Key Pair Used With SSL Encrypted Communications
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
IPSec Settings
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Checking a Device Signature Certificate
Setting a Rights Management Server
Copy Set Numbering Options
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Specifying Management Settings for the Hard Disk
Completely Erasing Unnecessary Data from the Hard Disk
Initializing All Data/Settings
TPM Settings
Device Management
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting Automatic Delivery
Setting Manual Delivery
Setting the Receiving Machine
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Retrieving Audit Logs
Saving a Log of Key Operations
Available Administrator Settings Table (Touch Panel Display)
Top » Security » Preventing Information Leakage » Digital Signatures
Digital Signatures
0S9Y-1HS
The machine can add the following two types of digital signatures to PDF or XPS files. This section describes the procedures for specifying and confirming the settings necessary for adding digital signatures to PDF or XPS files using the control panel of the machine. For instructions on adding digital signatures to PDF or XPS files, see "Adding a Digital Signature to a PDF or XPS" and "Installing a Certificate File."
For information on the optional products required to use these functions, see "Optional Products Required for Each Function."
Device Signature
Enables the recipient to identify the device that scanned the document. To add a device signature to a PDF or XPS file, set a key pair and device certificate.
