Alternating the Print Output (Offset Jobs)
0L3X-07L
The Offset Jobs mode automatically sorts the print output by job when multiple print jobs are specified. This ensures that output pages are always sorted, even if you forget to specify a finishing mode.
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
You cannot set [Offset Jobs] when paper is output to the top tray of the High Capacity Stacker-G1. You can set [Offset Jobs] when paper is output to the stack area of the High Capacity Stacker-G1.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Offset Jobs].
4.
Press [On] → [OK].
Select [Off] if you do not want to enable the Offset Jobs mode.
