Flow of Operations for General Users
If Department ID Management Is Used
Specify the following.
Press [Dept. ID] → enter a Department ID.
Press [PIN] → enter a PIN.
Press [Log in].
You can also press
(Log In/Out) to log in.
Press
(Settings/Registration).
4.
Display the desired setting from the list.
Operations that are restricted are grayed out and cannot be selected.
5.
Specify the setting → press [Close].
To move up one level, press [Up].
6.
When you finish specifying the settings, press [Log Out] at the bottom right of the screen to log out.
Press [User Name] → enter a user name → press [OK].
Press [Password] → enter a password → press [OK].
Press [Log In].
You can also press
Press
4.
5.
6.
If Both Department ID Management and SSO-H Are Not Used
Press
