Management Settings
Management Settings
Management Settings: User Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[System Manager Information Settings]
System Manager ID (Seven digits maximum)
7654321
Yes
Yes
System Manager PIN (Seven digits maximum)
7654321
Yes
Yes
System Manager
(NULL)
Yes
Yes
E-Mail Address
(NULL)
Yes
Yes
Contact Information
(NULL)
Yes
Yes
Comment
(NULL)
Yes
Yes
[Department ID Management]
Department ID Management: On, Off
Off
Yes
Yes
Register PIN: Register, Edit, Delete, Limit Functions
Yes
Yes
Page Totals: Clear, Print List, Clear All Totals, Large2 Count Management
Yes
No
Allow Printer Jobs with Unknown IDs: On, Off
On
Yes
Yes
Allow Remote Scan Jobs with Unknown IDs: On, Off
On
Yes
Yes
Allow Black & White Copy/Print Jobs: On, Off
Off
Yes
Yes
Allow Black & White Printer Jobs: On, Off
Off
Yes
Yes
Management Settings: Device Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Device Information Settings]
Device Name
Model Name
Yes
No
Location
(NULL)
Yes
No
[Device Information Distribution Settings]
[Register Destinations]
Auto Search/Register, Reg., Details, Delete, Print List
No
No
Auto Search/Register:
Search Depth (Router): 1 to 8
1
No
No
Display Host Name: On, Off
Off
No
No
Start Auto Search
No
No
[Set Auto Distribution]
Everyday (1 to 5), Specify Days (Sun to Sat, 1 to 5), Off
Off
No
No
Settings/Registration Value: On, Off
Network Settings: Include, Exclude
Off
Network Settings: Exclude
No
No
Dept. ID: On, Off
Off
No
No
Address Book: On, Off
Off
No
No
Web Access Favorites*1: On, Off
Off
No
No
Printer Settings: On, Off
Off
No
No
Paper Information: On, Off
Off
No
No
[Manual Distribution]
Off
No
No
Dept. ID: On, Off
Off
No
No
Off
No
No
Off
No
No
Off
No
No
Off
No
No
[Set MEAP Authentication]
User Name, Password, Login Destination
No
No
[Restrict Receiving Device Information]
On, Off
On
No
No
[Restore Data]
Settings/Reg. Value, Dept. ID, Address Book, Web Access Favorites*1, Printer Settings, Paper Information, Start
No
No
[Restrict Receiving for Each Function]
On
No
No
Dept. ID: On, Off
On
No
No
On
No
No
On
No
No
On
No
No
On
No
No
[Set Paper Information]
All, Basic Only
Basic Only
No
No
[Use MEAP Auth. When Receive]
On, Off
Off
No
No
[Communication Log]
Details, Print List, Report Settings
No
No
Report Settings
Auto Print (100 Transmissions): On, Off
On
No
No
Specify Print Time: On, Off
Off
No
No
00:00 to 23:59
00:00
No
No
Separate Report Type: On, Off
Off
No
No
[Limited Functions Mode]*1
On, Off
Off
No
No
Finisher Tray A/B: On, Off
Off
No
No
Finisher Saddle Stitch Unit: On, Off
Off
No
No
Folding Unit: On, Off
Off
No
No
Finisher Puncher: On, Off
Off
No
No
Stacker: On, Off
Off
No
No
Perfect Binder: On, Off
Off
No
No
[Confirm Device Signature Certificate]*1
Certificate Details: Verify Cert.
Yes
No
[Confirm User Signature Certificate]*1
Yes
No
[Certificate Settings]
[Generate Key]
[Generate Network Communication Key]
Key Name
(NULL)
Yes
No
Signature Algorithm: SHA1, SHA256, SHA384, SHA512
SHA1
Yes
No
Key Algorithm: RSA, ECDSA
RSA
Yes
No
When RSA is selected
Key Length (bit): 512, 1024, 2048, 4096
512
Yes
No
When ECDSA is selected
Key Type: P256, P384, P521
P256
Yes
No
Validity Start Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Validity End Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Country/Region: Country/Region name and code
United States (US)
Yes
No
State
(NULL)
Yes
No
City
(NULL)
Yes
No
Organization
(NULL)
Yes
No
Organization Unit
(NULL)
Yes
No
Common Name (IP address of the machine or FQDN (41 characters maximum))
(NULL)
Yes
No
[Generate/Update Device Signature Key]
(See "Setting a Key Pair and Device Certificate.")
Yes, No
Yes
No
[Key and Certificate List]
[Key and Certificate List for Users]*1
Certificate Details: (Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Delete
Yes
No
[Key and Certificate List for This Device]*1
(See "Confirming a Key Pair and Device Certificate.")
Yes
No
Delete
Yes
No
Display Use Location (Key and Certificate)
Yes
No
[CA Certificate List]
Yes
No
Delete
Yes
No
[Cert. Revocation List (CRL)]
CRL Details: Serial Number, Expires, Verify CRL
Yes
No
Delete
Yes
No
[Register Key and Certificate]
Register
Yes
No
Delete
Yes
No
[Register CA Certificate]
Register
Yes
No
Delete
Yes
No
[Display Job Status Before Authentication]
On, Off
On
Yes
No
[Display Job Log]
On, Off
On
Yes
No
Off
Retrieve Job Log with Management Software: Allow, Do Not Allow
Do Not Allow
Yes
No
[Save Audit Log]
On, Off
Off
Yes
No
[Store Key Operation Log]
On, Off
Off
Yes
No
[Format Encryption Method to FIPS 140-2]
On, Off
Off
Yes
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Management Settings: License/Other
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Register License]
24 characters maximum, Start
(NULL)
No
No
[MEAP Settings]
[Print System Information]
Yes, No
No
No
[Use SSL]
On, Off
Off
Yes
No
[Remote UI]
On, Off
On
No
Yes
On
Access by General User: Allow, Do Not Allow
Allow
No
No
Access PIN (seven digits)
No
No
Use SSL:
On, Off
Off
Yes
No
Use Reference Print*1:
On, Off
Off
Yes
Yes
[Delete Message Board Contents]
Yes, No
No
No
[Use ACCESS MANAGEMENT SYSTEM]*1
(See "ACCESS MANAGEMENT SYSTEM.")
On, Off
On
Yes
No
[Register/Update Software]*2
Install Applications/Options, Software Management Settings
Yes
No
[Remote Operation Settings](See "Remote Operation.")
On, Off
Off
Yes
No
*1
Indicates items that appear only when the appropriate optional product is available for use.
*2
For more information, see "Adding New Functions."
Management Settings: Data Management
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[HDD Data Complete Deletion]*1
[Hard Disk Data Complete Deletion]
On, Off
Off
Yes
No
[Timing of Deletion]
During Job, After Job
During Job
Yes
No
[Overwrite Method for Deletion Mode]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, DoD Standard
Yes
No
[Initialize All Data/Settings]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, 9 Times with Random Data, DoD Standard
No
No
[TPM Settings]
Use TPM: On, Off
Off
No
No
Back Up TPM Key(12 characters maximum for password), Restore TPM Key
No
No
*1
» Settings/Registration » Settings/Registration Table » Management Settings
0L3X-056
