Changing the Default Screen for Send
You can set whether to display the [Standard], [One-Touch], [Favorite Settings], or [Address Book] screen when you select a function from the Main Menu, when Auto Reset is activated, or when you press (Reset).
Press [Function Settings] → [Send] → [Common Settings].
Press [Default Screen].
4.
Specify the settings to set as default → press [OK].
If you select [Address Book], you can select the type of address book to display. For more information, see "Changing the Default Display of the Address Book."
» Settings/Registration » Function Settings » Send » Common Settings » Changing the Default Screen for Send
0L3X-0A3
