This function is only valid when operating Copy function.
To use this function, set [Consider Color] for [Copy] to 'On' in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration). (See "Enabling Paper Drawer Auto Selection.")
(Settings/Registration).|
[Color]:
Paper sources with [Color] setting are used if you select [Auto (Color/B&W)], [Full Color], [Single Color], or [Two Colors] in [Select Color] when copying.
[B&W]:
Paper sources with [B&W] setting are used if you select [B&W] in [Select Color] when copying.
: Stack Bypass-B1 |
: Upper Paper Drawer |
: Middle Paper Drawer |
: Lower Paper Drawer |
: POD Deck Lite-B1 |
: Upper Paper Deck of the Multi-drawer Paper Deck-B1 |
: Middle Paper deck of the Multi-drawer Paper Deck-B1 |
: Lower Paper Deck of the Multi-drawer Paper Deck-B1 |
In the following cases, the paper source which is set to [Color] is automatically selected regardless of the color mode specified when copying.
When the Merge Job Blocks mode is set
When both the Different Size Originals mode and the Job Build mode is set
