Handling Files That Fail to Be Forwarded
You can set how the machine handles files that fail to be forwarded.
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [Handle Files with Forwarding Errors].
4.
Specify the following setting → press [OK].
Details of each item are shown below:
[Always Print]:
Files that fail to be forwarded are printed.
[Store/Print]:
Files that fail to be forwarded are stored in the Memory RX Inbox. The machine automatically prints the files that fail to be forwarded if Use I-Fax Memory Lock mode is set to 'Off' in [Function Settings] (Settings/Registration). (See "Specifying the I-Fax Inbox Settings.")
[Off]:
Files that fail to be forwarded are not printed.
To set [Handle Files with Forwarding Errors], you need to log in to the machine as an administrator.
If you set [Delete Failed TX Jobs] to 'Off' in [Function Settings] (Settings/Registration), the status of any job with a forwarding error will be saved on the Status Monitor/Cancel screen. The file will not be processed according to the settings you make for [Handle Files with Forwarding Errors]. (See "Automatically Deleting Failed Jobs.")
» Settings/Registration » Function Settings » Receive/Forward » Common Settings » Handling Files That Fail to Be Forwarded
0L3X-0E2
