Perfect Binding Finishing Size
0L3X-09C
You can register finishing sizes for the perfect binding, assign them names, and edit or delete them as necessary. This mode is useful for registering frequently used finishing sizes.
This mode can be set when the Perfect Binder-D1 is attached. For more information, see the instruction manual for the Perfect Binder-D1.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Register Finishing Size].
Press [Perfect Binding Finishing Size].
4.
Select a desired setting from the following items:
To register/edit a finishing size for the perfect binding:
Select a button ([S1] to [S5]) to register or edit a finishing size → press [Register/Edit].
Press [X] and [Y] → enter each value → press [OK].
You can also use numeric keys to enter values.
To register a name of the finishing size for the perfect binding:
Select a button ([S1] to [S5]) to name → press [Rename].
Enter a new name → press [OK].
To delete a finishing size for the perfect biding:
Select the finishing size that you want to delete → press [Delete].
Press [Yes].
5.
Press [Close].
Make sure to check the settings first before deleting them.
If you select a button that already has settings stored in it, the settings are displayed.
If you make a mistake when entering values, press  (Clear) → enter the correct values.
You can also name buttons with no settings stored in them.
If you press [OK] without entering any characters, the button name reverts to its current name (default S1 to S5).
The paper size settings stored in memory are not deleted, even if the machine's main power switch is turned OFF.
