Setting When to Deactivate the Perfect Binder Energy Saver Mode
You can set whether to automatically deactivate the Energy Saver mode of the Perfect Binder-D1 when the Energy Saver mode of the main unit is deactivated.
This mode can be set when the Perfect Binder-D1 is attached. For more information, see the instruction manual for the Perfect Binder-D1.
Press [Preferences] → [Timer/Energy Settings] → [End the Perfect Binder Energy Saver Mode].
Select [Sync with Main Unit] or [Do Not Sync w/Main Unit] → press [OK].
Details of each item are shown below.
[Sync with Main Unit]:
The Energy Saver mode of the Perfect Binder-D1 is automatically deactivated when the Energy Saver mode of the main unit is deactivated.
[Do Not Sync w/Main Unit]:
The Energy Saver mode of the Perfect Binder-D1 is not deactivated when the Energy Saver mode of the main unit is deactivated. Press the Energy Saver key of the Perfect Binder-D1 to cancel its Energy Saver mode.
» Settings/Registration » Preferences » Timer/Energy Settings » Setting When to Deactivate the Perfect Binder Energy Saver Mode
0L3X-072
