e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Hold
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Distinguishing B5 and EXEC Paper
Registering Multi-Purpose Tray Defaults
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Switching the Copy Basic Features Screen
Display Fax Function
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Changing the Default Display of Select Paper List Screen
Setting the Default Display of the Paper Type Selection Screen
Changing Default Display for Paper Type List
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Changing the Puncher Die Name
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Time Settings for Auto Adjust Gradation
Setting the Energy Saver/Sleep Mode Exit Time
Switching Modes Activated After Pressing Energy Saver Key
Changing the Energy Saver Mode
Low Power Mode Time
Perfect Binder Energy Saver Mode Time
Setting When to Deactivate the Perfect Binder Energy Saver Mode
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Specifying the Maximum Number of Sheets to Load in the Stacker
Auto Eject Paper on Stacker Tray
High Volume Stack Mode
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Inserting a Job Separation Sheet after Clearing a Paper Jam in the Stacker
Outputting Different Sized Papers to the Same Output Tray
Aligning Output Paper of Different Width
Forcing to Output Excess Tab Paper
Normal/Reverse Order Output with External Finisher
Face UP/Face Down Output with External Finisher
Image Orientation When Output with External Finisher
Print Settings
Setting the Printing Priority
Heavy 5/Heavy 6 Paper Productivity Priority
Coated Paper Productivity/Gloss Priority
Productivity/Image Quality Priority for Mixed Paper Type
Outputting Reports with Two-Sided Printing
Registering Forms for the Superimpose Image Mode
Setting the Image Priority
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Improving Productivity for a Print Job Contains Both One-Sided Printing and Two-Sided Printing
Scan Settings
Timing to Raise Feeder Tray
Feeder Jam Recovery Method
Scanner Noise Settings
Streak Prevention
Black Scan Speed/Image Quality Priority
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
High Compression/Limited Color Image Quality Level
Setting the Resolution for Limited Color PDF
Settings for Creating Searchable PDF/XPS/OOXML
Trace & Smooth Settings
OOXML Settings
Deleting Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Register Finishing Size
Perfect Binding Finishing Size
Registering/Editing/Deleting Finishing Size for Finishing/Booklet (Trim).
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Registering Express Copy Shortcut Buttons
Enabling Auto Collating
Giving Priority to Image Orientation
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Outputting Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Send
Changing the Default Settings for Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data Into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN upon Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Auto Complete for E-mail Address Entry
Specifying the Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for the Fax Function
Registering/Editing/Deleting Sender Names
Setting the Authenticated User Name as the Sender Name (TTI)
Fax TX Report
Fax Activity Report
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Outputting Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Gamma Value for YCbCr Receive Jobs
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Editing Forwarding Settings
Printing Forwarding Settings
Specifying the I-Fax Inbox Settings
Always Send Notice for RX Errors
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Forcing Seven Digit Mail Box PINs
Mail Box Settings
Memory Media Settings
Hold
Specifying the Hold Function
Setting the Time Until a Hold Job is Automatically Deleted
Storing Jobs with PS/PDF Data in the Hold Queue
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Function Settings » Send » E-Mail/I-Fax Settings » Common Communication Settings for E-Mail/I-Fax
0L3X-0AL
Press [Function Settings] → [Send] → [E-Mail/I-Fax Settings].
Press [Communication Settings] → set the e-mail server.
The machine supports POP3, and can also function as an SMTP receive server.
The machine can only receive I-faxes and communication error notices.
Using the machine as an SMTP receive server:
Using a POP server to receive communications:
Logging in to a POP server before sending (POP before SMTP):
Logging in to an SMTP server before sending (SMTP Authentication):
Sending without authenticating:
Press [On] for <SMTP RX> → [Off] for <POP>.
Press [E-Mail Address].
Enter the e-mail address → press [OK].
Press [Authent./Encryption] → set <Allow SSL (SMTPReceive)> → press [OK].
If you select [Always SSL] for <Allow SSL (SMTPReceive)>, only reception of data encrypted using SSL is allowed, and communications not using SSL from the host are rejected.
If you select [On] for <Allow SSL (SMTPReceive)>, receiving SSL encrypted data may only be allowed when there is a request from the host.
To use the SMTP receiving function, it is necessary to register the host name for the machine to the DNS server. (See "TCP/IPv4 Settings" and "TCP/IPv6 Settings.")
Even if you select [On] for <Allow SSL (SMTPReceive)>, the data will not be encrypted if the SMTP host does not support encryption.
To select [Always SSL] or [On] for <Allow SSL (SMTPReceive)> to allow SSL transmission, it is necessary to generate a key pair in advance. To generate a key pair, see "Generating a Key Pair and Server Certificate" or "Registering a Key Pair File and Server Certificate File Installed from a Computer."
Press [Off] for <SMTP RX> → [On] for <POP>.
Press [POP Server].
Enter the IP address or name for the POP server → press [OK].
Press [POP Login Name].
Enter the POP login name → press [OK].
Press [POP Password].
Enter the POP password → press [OK].
Specify the time interval to automatically check the POP server in <POP Interval>.
Press [Authent./Encryption] → set <POP AUTH Method>.
Set <Allow SSL (POP)> → press [OK].
If you want to send encrypted data, set <POP> to 'On'.
If you set less than 10 minutes (excluding '0 min') for <POP Interval>, the machine will not enter a complete Sleep mode.
Even if you select [On] for <Allow SSL (POP)>, the data will not be encrypted if the POP server does not support encryption.
Press [SMTP Server].
Enter the IP address or name for the SMTP server → press [OK].
Press [POP Server].
Press [On] for <POP Authentication Before Send> → [Off] for <SMTP Authentication (SMTP AUTH)>.
Set <Allow SSL (POP)> → <Allow SSL (SMTP Send)> → press [OK].
If you want to send encrypted data, set <Allow SSL (POP)> or <Allow SSL (SMTP Send)> to 'On'.
Even if you select [On] for <Allow SSL (SMTP Send)>, the data will not be encrypted if the SMTP host does not support encryption.
Press [Authent./Encryption] → [Off] for <POP Authentication Before Send>.
Press [On] for <SMTP Authentication (SMTP AUTH)> → [User Name].
Enter the user name for logging in to the SMTP server → press [OK].
If you are using a Microsoft SMTP server, enter the user name using the following format: user name@domain name. For more information, confirm the Microsoft SMTP server settings.
Press [Password].
Enter the password for logging in to the SMTP server → press [OK].
Set <Allow SSL (SMTP Send)> → <Display Auth. Screen When Send> → press [OK].
If you want to send encrypted data, set <Allow SSL (SMTP Send)> to 'On'.
If you want to display the authentication screen when sending, set <Display Auth. Screen When Send> to 'On'.
Press [Off] for <SMTP Authentication (SMTP AUTH)>.
Set <Allow SSL (SMTP Send)> → press [OK].
4.
Press [OK].
