Setting the Paper Size Group for Auto Recognition in the Paper Source
You can register the paper size group for each paper source to make the machine detect the loaded paper size automatically. This setting is useful if you always load the same size of paper into each paper source.
You can set the paper size group for automatic paper size detection for stack bypass when the Stack Bypass-B1 is attached.
Be sure to correctly register the paper size. Registering the paper size incorrectly may result in a paper jam.
Press [Preferences] → [Paper Settings] → [Paper Size Group for Auto Recog. in Drawer].
Select the paper size group that you want to use for automatic paper size detection for each paper source → press [OK].
Details of each item are shown below.
Paper Drawer:
All Sizes, A/B Size, Inch Size
Multi-purpose Tray:
A/B Size, Inch Size
Each button represents the following paper sources:
The POD Deck Lite-B1 and Stack Bypass-B1 are attached.
: Stack Bypass-B1
: Upper Paper Drawer
: Middle Paper Drawer
: Lower Paper Drawer
: POD Deck Lite-B1
The Multi-drawer Paper Deck-B1 is attached.
: Upper Paper Deck of the Multi-drawer Paper Deck-B1
: Middle Paper deck of the Multi-drawer Paper Deck-B1
: Lower Paper Deck of the Multi-drawer Paper Deck-B1
» Settings/Registration » Preferences » Paper Settings » Setting the Paper Size Group for Auto Recognition in the Paper Source
0L3X-05A
