Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
(Settings/Registration). |
To select an A or B series paper size, press [A/B Size].
If the envelope type is not set correctly, a paper jam will occur.
[Transparency] can be selected only if you select [LTR] as the paper size.
For more information on paper types, see "Available Paper Stock."
You can register paper types that are not displayed on the detailed settings list in <Paper Settings: Paper Type>. For instructions on registering paper types, see "Registering Custom Paper Types."
To use the Stack Bypass-B1 as a paper source for [Copy], [Access Stored Files], [Receive], or [Other], you must set so that the Stack Bypass-B1 is eligible for Paper Drawer Auto Selection. (See "Enabling Paper Drawer Auto Selection.")
