Default Screen (Status Monitor/Cancel)
0L3X-05L
You can change the screen that appears when you press
(Status Monitor/Cancel).
Press
(Settings/Registration).
Press [Preferences] → [Display Settings] → [Default Screen (Status Monitor/Cancel)].
Specify the settings → press [OK].
If you select [Job] in <Default Status Type>, you can set <Status/Log> and <Details>.
If you set [Job], [Job Status], [Print] as the Default Screen (Status Monitor/Cancel):
If you set [Paper] as the Default Screen (Status Monitor/Cancel):
If you set [Toner/Other] as the Default Screen (Status Monitor/Cancel):
