e-ManualTopSite mapHelp
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Hold
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Distinguishing B5 and EXEC Paper
Registering Multi-Purpose Tray Defaults
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Switching the Copy Basic Features Screen
Display Fax Function
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Changing the Default Display of Select Paper List Screen
Setting the Default Display of the Paper Type Selection Screen
Changing Default Display for Paper Type List
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Changing the Puncher Die Name
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Time Settings for Auto Adjust Gradation
Setting the Energy Saver/Sleep Mode Exit Time
Switching Modes Activated After Pressing Energy Saver Key
Changing the Energy Saver Mode
Low Power Mode Time
Perfect Binder Energy Saver Mode Time
Setting When to Deactivate the Perfect Binder Energy Saver Mode
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Specifying the Maximum Number of Sheets to Load in the Stacker
Auto Eject Paper on Stacker Tray
High Volume Stack Mode
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Inserting a Job Separation Sheet after Clearing a Paper Jam in the Stacker
Outputting Different Sized Papers to the Same Output Tray
Aligning Output Paper of Different Width
Forcing to Output Excess Tab Paper
Normal/Reverse Order Output with External Finisher
Face UP/Face Down Output with External Finisher
Image Orientation When Output with External Finisher
Print Settings
Setting the Printing Priority
Heavy 5/Heavy 6 Paper Productivity Priority
Coated Paper Productivity/Gloss Priority
Productivity/Image Quality Priority for Mixed Paper Type
Outputting Reports with Two-Sided Printing
Registering Forms for the Superimpose Image Mode
Setting the Image Priority
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Improving Productivity for a Print Job Contains Both One-Sided Printing and Two-Sided Printing
Scan Settings
Timing to Raise Feeder Tray
Feeder Jam Recovery Method
Scanner Noise Settings
Streak Prevention
Black Scan Speed/Image Quality Priority
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
High Compression/Limited Color Image Quality Level
Setting the Resolution for Limited Color PDF
Settings for Creating Searchable PDF/XPS/OOXML
Trace & Smooth Settings
OOXML Settings
Deleting Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Register Finishing Size
Perfect Binding Finishing Size
Registering/Editing/Deleting Finishing Size for Finishing/Booklet (Trim).
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Registering Express Copy Shortcut Buttons
Enabling Auto Collating
Giving Priority to Image Orientation
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Outputting Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Send
Changing the Default Settings for Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data Into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN upon Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Auto Complete for E-mail Address Entry
Specifying the Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for the Fax Function
Registering/Editing/Deleting Sender Names
Setting the Authenticated User Name as the Sender Name (TTI)
Fax TX Report
Fax Activity Report
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Outputting Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Gamma Value for YCbCr Receive Jobs
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Editing Forwarding Settings
Printing Forwarding Settings
Specifying the I-Fax Inbox Settings
Always Send Notice for RX Errors
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Forcing Seven Digit Mail Box PINs
Mail Box Settings
Memory Media Settings
Hold
Specifying the Hold Function
Setting the Time Until a Hold Job is Automatically Deleted
Storing Jobs with PS/PDF Data in the Hold Queue
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Settings/Registration Table » Function Settings » Function Settings: Printer
0L3X-04X
The following table lists all settings of the Printer Settings menu.
Output Report
Item
Settings
Default Settings
Can be set in Remote UI
Device Information
Delivery Available
PCL*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS*1
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
RGB Test Page
Yes, No
Yes
No
CMYK Test Page
Yes, No
Yes
No
RGB Color Chart
Yes, No
Yes
No
CMYK Color Chart
Yes, No
Yes
No
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
Common Settings (Printer Settings > Custom Settings)
Item
Settings
Default Settings
Can be set in
Remote UI
Device Information
Delivery Available
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
Letter, Legal, A4, B5, A3, B4, A5, 11x17, Executive, Statement, Env. YOGATANAGA3, Envelope DL, Envelope Monarch, Env. No. 10, Envelope ISO-C5, Env. KAKUGATA 2, Env. NAGAGATA 3, 12_5/8x17_11/16, 12x18, 13x19
Letter
Yes
No
[Default Paper Type]
Thin 2, Thin 1, Plain 1, Plain 2, Heavy 1, Heavy 2, Heavy 3, Heavy 4, Heavy 5, Heavy 6, Color 1, Color 2, Recycled 1, Recycled 2, Recycled 3, Pre-punched 1, Pre-punched 2, Transparency, Labels, Bond 1, Bond 2, Bond 3, Letterhead, 1-Sided Coated 1, 1-Sided Coated 2, 1-Sided Coated 3, 1-Sided Coated 4, 1-Sided Coated 5, 1-Sided Coated 6, 2-Sided Coated 1, 2-Sided Coated 2, 2-Sided Coated 3, 2-Sided Coated 4, 2-Sided Coated 5, 2-Sided Coated 6, Matte Coated 1, Matte Coated 2, Matte Coated 3, Matte Coated 4, Matte Coated 5, Matte Coated 6, Textured 1, Textured 2, Textured 3, Textured 4, Textured 5, Textured 6, Textured 7, Textured 8, Vellum 1, Vellum 2, Vellum 3, Tab 1, Tab 2, Envelope, Clear Film
Plain 1
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Paper Output]
[Output Destination]*1
Finisher, Stacker, Stacker(Tray)
Finisher
Yes
No
[Spec. no of Copies Stk.]*1
Copies, Off
Off
Yes
No
No. of Copies: (1 to 9999)
1
Yes
No
[Finishing]
Off, Collate, Group, Rotate+Collate*1, Rotate+Group*1, Offset+Collate*1, Offset+Group*1, Staple+Collate*1, Staple+Group*1
Copies to Offset (Offset+Collate):
1 to 9999
Staple Position (Staple+Collate):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), and Double (Left)
Staple Position (Staple+Group):
Grp Upp L-Corner, Grp Double (Top), Grp Upp R-Corner, Grp Double (R), Grp Lwr R-Corner, Grp Double (Btm), Grp Lwr L-Corner, Grp Double (L)
Group
Yes
Yes
[Punch]*1
Off, Top, Bottom, Left, Right
Off
Yes
No
[Fold]*1
Off, Z-Fold, C-Fold
Off
Yes
No
[Face Up/Down]
Face Down, Face Up
Face Down
Yes
Yes
[Print Quality]
[Density]*1(See "Density.")
Cyan:
-8 to +8
Magenta:
-8 to +8
Yellow:
-8 to +8
Black:
-8 to +8
0
Yes
Yes
[Density (Fine Adjust)]*1
(See "Density (Fine Adjust).")
Cyan:
High:
-8 to +8
Medium:
-8 to +8
Low:
-8 to +8
Magenta:
High:
-8 to +8
Medium:
-8 to +8
Low:
-8 to +8
Yellow:
High:
-8 to +8
Medium:
-8 to +8
Low:
-8 to +8
Black:
High:
-8 to +8
Medium:
-8 to +8
Low:
-8 to +8
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Img Compress. Optimization]
On, Off
Off
Yes
Yes
[Sharpness]
-3 to +3
0
Yes
Yes
[Trapping]
Trapping: On, Off
Off
Yes
Yes
Trapping Width:
Upper: 0 to 3 pixel
Lower: 0 to 3 pixel
Left: 0 to 3 pixel
Right: 0 to 3 pixel
1 pixel
Yes
Yes
Trapping Density:
Cyan: 0 to 100 %
Magenta: 0 to 100 %
Yellow: 0 to 100 %
100 %
Yes
Yes
[Toner Volume Correction]
Normal, Grad. Priority, Text Priority
Normal
Yes
Yes
[Line Control]
(See "Line Control.")
Res. Priority, Grad. Priority
Res. Priority
Yes
Yes
[Width Adjustment]
Width Adjustment: On, Off
Horizontal: Off, Level 1, Level 2
Vertical: Off, Level 1, Level 2
Target Color: All, Black Only
Off
Level 1
Level 1
All
Yes
Yes
[Advanced Smoothing]
Advanced Smoothing: Off, Level 1, Level 2
Apply to Graphics: On, Off
Apply to Text: On, Off
Level 1
Off
On
Yes
Yes
[Gradation Smoothing]
Gradation Smoothing: Off, Level 1, Level 2
Apply to Images: On, Off
Off
On
On
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-1.90 to +1.90 inches
0.00
Yes
Yes
[Offset Short Edge (Front)]
-2.00 to +2.00 inches
0.00
Yes
Yes
[Offset Long Edge (Front)]
0.00
Yes
Yes
[Offset Short Edge (Back)]
0.00
Yes
Yes
[Offset Long Edge (Back)]
0.00
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
[Print After Completing RIP]
On, Off
Off
Yes
Yes
[Booklet]
Off, Left Opening, Right Opening
Off
Yes
Yes
[Saddle Stitch]*1
On, Off
Off
Yes
Yes
[Creep Correction]*1
Off, Auto, Correction Width
Off
Yes
Yes
[Use Cover Inserter]*1
If the Document Insertion Unit-M1 is attached:
Off, Inserter 1, Inserter 2
Off
Yes
No
[Transparency Interleaving]*1
(See "Transparency Interleaving.")
Off, Blank, Printed
Off
Yes
Yes
[Copy Set Numbering]
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
[Small(12 point)], [Medium(24 point)], [Large(36 point)]
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Color]*1
Yellow, Magenta, Cyan, Black, Red, Green, Blue
Black
Yes
Yes
[Number Position Vertical]*1
-5/16 to +5/16 inches
0
Yes
Yes
[Number Position Horizontal]*1
0
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.")
None, PS, PCL, PDF
None
Yes
No
[Color Mode]
Auto (Color/B&W), Color, Black & White
Auto (Color/B&W)
Yes
Yes
[Compressed Image Output]
Output, Display Error
Output
Yes
Yes
[Initialize]
Yes, No
No
Yes
*1
UFR II Settings (Printer Settings > Custom Settings > UFR II)
Item
Settings
Default Settings
Device Information
Delivery Available
[Halftones]
Text: Resolution, Gradation, Error Diffusion
Resolution
Yes
Yes
Graphics: Resolution, Gradation, Error Diffusion
Gradation
Image: Resolution, Gradation, Error Diffusion
Gradation
[RGB Source Profile]
Text: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
Yes
No
Graphics: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
Image: sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, Download Profile
sRGB
[Output Profile]
Text: Normal, Photo
Yes
No
Graphics: Normal, Photo
Image: Normal, Photo
[Matching Method]
Text: Perceptual, Saturation, Colorimetric
Perceptual
Yes
Yes
Graphics: Perceptual, Saturation, Colorimetric
Perceptual
Image: Perceptual, Saturation, Colorimetric
Perceptual
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[CMS(Matching) Selection]
Printer, Host
Printer
Yes
Yes
[CMS(Matching)/Gamma]
Text: Gamma, CMS
Gamma
Yes
Yes
Graphics: Gamma, CMS
Gamma
Image: Gamma, CMS
Gamma
[Gamma Correction]
Text: 1.0, 1.4, 1.8, 2.2
1.4
Yes
Yes
Graphics: 1.0, 1.4, 1.8, 2.2
1.4
Image: 1.0, 1.4, 1.8, 2.2
1.4
[Paper Save]
On, Off
On
Yes
Yes
PCL Settings (Printer Settings > Custom Settings > PCL) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
64 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
5.82 inches to 24.80 inches
19.20 inches
Yes
No
[Y dimension]*1
3.93 inches to 13.00 inches
13.00 inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Image: Gradation, Resolution, Error Diffusion
Gradation
(See "RGB Source Profile.")
sRGB
Yes
No
sRGB
sRGB
[Output Profile]
(See "Output Profile.")
Text: Normal, Photo
Yes
No
[Matching Method]
(See "Matching Method.")
Perceptual
Yes
Yes
Perceptual
Perceptual
[Gray Compensation]
(See "Gray Compensation.")
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[CMS (Matching) Selection]
(See "CMS (Matching) Selection.")
Printer, Host
Printer
Yes
Yes
(See "CMS (Matching)/Gamma.")
Text: Gamma, CMS
Gamma
Yes
Yes
Gamma
Image: Gamma, CMS
Gamma
[Gamma Correction]
(See "Gamma Correction.")
1.4
Yes
Yes
1.4
1.4
[BarDIMM]
Enable, Disable
Disable
Yes
Yes
[FreeScape]*1
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
*2
PCL Printer only.
PS Settings (Printer Settings > Custom Settings > PS) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Job Timeout]
0 to 3600 seconds
0
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*1
On, Off
On
Yes
Yes
[Matching Mode]
[RGB Input]
ICC Profile, D. Link Profile
ICC Profile
Yes
No
[CMYK Input]
ICC Profile
Yes
No
sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, None, Download Profile
sRGB
Yes
No
[CMYK Simulation Profile]
JapanColor(Canon, US Web Ctd(Canon, Euro Standard, None, Download Profile
None
Yes
No
[Use Grayscale Profile]
(See "Use Grayscale Profile.")
On, Off
Off
Yes
No
[Output Profile]
Normal, Photo, TR Normal, TR Photo, Download Profile
Yes
No
[Matching Method]
Perceptual
Yes
Yes
[Device Link Profile]
(See "Device Link Profile.")
[RGB Input(Light+ClrSpace)]
D50 + sRGB, D65 + sRGB, D50 + Adobe RGB, D65 + Adobe RGB, Profile Name
D50 + sRGB
Yes
No
[CMYK Input(Light+ClrSpace)]
D50 + JapanColor, Profile Name
D50 + JapanColor
Yes
No
[RGB Pure Black Process]
(See "RGB Pure Black Process.")
On, Off
Off
Yes
Yes
[CMYK Pure Black Process]
(See "CMYK Pure Black Process.")
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Gradation
[Brightness]*1
(See "Brightness.")
85% to 115%
100%
Yes
Yes
[Spot Color Matching]
(See "Spot Color Matching.")
On, Off
Off
Yes
Yes
[Composite Overprint]
(See "Composite Overprint.")
On, Off
Off
Yes
Yes
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
*1
*2
PS Printer only.
Imaging Settings (Printer Settings > Custom Settings > Imaging) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Matching Mode]
[RGB Input]
ICC Profile
Yes
No
[CMYK Input]
ICC Profile
Yes
No
D50 + sRGB, D65 + sRGB, D50 + Adobe RGB, D65 + Adobe RGB, Download Profile
D50 + sRGB
Yes
No
D50 + JapanColor, Download Profile
D50 + JapanColor
Yes
No
[ICC Profile Settings]
sRGB
Yes
No
None
Yes
No
On, Off
Off
Yes
No
[Output Profile]
Yes
No
[Matching Method]
Perceptual
Yes
Yes
[Photo Correct.(Color Only)]
[Photo Optimizer PRO]
On, Off
Off
Yes
No
[Red-Eye Correction]
Red-Eye Correction: On, Off
Off
Yes
No
Red-Eye Correction Level: Weak, Standard, Strong
Standard
Yes
No
[Face Brightener]
Face Brightener: On, Off
Off
Yes
No
Face Brightener Level: Weak, Standard, Strong
Standard
Yes
No
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[Halftones]
Gradation
Yes
Yes
NTSC
Yes
Yes
*1
*2
Settings are applicable only for the Imaging mode of Direct Print.
PDF Settings (Printer Settings > Custom Settings > PDF) *2
Item
Settings
Default Settings
Device Information
Delivery Available
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*1
On, Off
On
Yes
Yes
[Matching Mode]
[RGB Input]
ICC Profile
Yes
No
[CMYK Input]
ICC Profile
Yes
No
sRGB
Yes
No
None
Yes
No
On, Off
Off
Yes
No
[Output Profile]
Yes
No
[Matching Method]
Perceptual
Yes
Yes
D50 + sRGB
Yes
No
D50 + JapanColor
Yes
No
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[Halftones]
Resolution
Yes
Yes
Gradation
Gradation
[Brightness]*1
(See "Brightness.")
85% to 115%
100%
Yes
Yes
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
NTSC
Yes
Yes
*1
*2
PS Printer only.
Utility Settings (Printer Settings > Utility)
Item
Settings
Default Settings
Device Information
Delivery Available
[Initialize PCL Hard Disk]*1
Yes, No
No
No
[Initialize PS Hard Disk]*1
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
*1
Printer Menu
Item
Settings
Default Settings
Device Information
Delivery Available
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
When On is selected:
Select Jobs to Allow: Rsrvd Jobs, Rsrvd Jobs + Secure Print
Rsrvd Jobs
Yes
Yes
[PDL Selection (Plug and Play)]
UFR II*1, PCL5c*1, PCL6*1, PS3*1
UFR II
Yes
No
*1
