Category
Top » Copy » Repeat Images
Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Store in Mail Box
Superimpose Image
Cascade Copy
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
Collapse all|Expand all
Repeat Images
This mode enables you to repeatedly copy the entire original image in either the vertical or horizontal direction.
Press [Copy].
Press [Options] → [Repeat Images].
Set the number of times that you want the image to repeat for both the vertical and horizontal directions.
Automatic Setting:
Manual Setting:
Automatic Setting:
Copies the image so that the maximum possible number of repeats fit on the selected paper size.
Press [Auto].
Manual Setting:
Copies the image the specified number of times.
Example: If "3 times" is selected
Images overlap when copied.
Press [-] or [+] to set the number of times that you want the image to repeat.
The repeated images may overlap or have gaps between them, depending on the number of repeats that you set.
4.
To specify the amount of the space between repeated images, press [Set Margins].
If you do not want to specify [Set Margins], proceed to step 6.
5.
Specify the amount of space to leave between repeated images using [-] and [+].
If you want to set the same width for all four borders:
If you want to set the width for each border independently:
Press [-] and [+] to set the amount of space → press [OK].
Press [Adjust Independently].
Select the space to adjust → press [-] and [+] to set the amount of space → press [OK].
To return to the screen for setting the same amount of space for all four sides, press [Uniform Width].
6.
Press [OK] → [Close].
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
