If you set [Auto XY Ratio], manually select a paper size. If you do not specify a paper size, the copy ratio is set to match the size of the paper loaded in Paper Drawer 1 or the right paper deck of the main unit.
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
You cannot enlarge/reduce highly transparent originals, such as transparencies, in [Auto XY Ratio]. Manually specify the copy (zoom) ratio for these types of originals.
If you set the copy ratio in [Auto XY Ratio], Auto Orientation is not performed.
If you set the copy (zoom) ratio in [XY Ratio], the image of the original may be rotated before being printed. The machine calculates whether or not to do this based on the original size and the specified copy (zoom) ratio.
If the output size differs from your specified copy ratio, you can adjust it using [Fine Adjust Zoom] in [Adjustment/Maintenance] (Settings/Registration). (See "Fine Adjust Zoom.")
