1
[Direct]
Press to make copies the same size as your original.
2
[Copy Ratio]
Press to specify the desired copy ratio.
3
[Select Paper]
Press to select the paper size/type and the paper source.
4
[Copy Sample]
This mode enables you to check the copy result before making multiple copies. |
5
<Confirm Settings>
Press to check, edit, or clear the current copy settings. |
6
![]() You can specify the following settings:
Register/Edit Favorite Settings
Register to Quick Menu (See "Quick Menu.")
Changing the Default Settings
Register Options Shortcuts
7
[Favorite Settings]
Press to register frequently used copy settings. You can also recall registered settings. |
8
[Previous Settings]
Press to recall the three most recent copy settings. |
9
[Options]
Press to specify other settings. You can configure a range of copy functions.
10
[Interrupt]
The interrupt mode enables you to pause a reserved or current job to make higher priority copies.
1
[Book
![]() Press to select or deselect the Book
2
[2-Sided]
Press to specify the 2-Sided Settings. Press to make [1-Sided
3
[Finishing]
Press to select the Collate, Group, or Staple mode. |
4
[Booklet]
Press to make a booklet by copying several originals. |
5
[Insert Sheets]
Press to insert blank sheets or chapter pages between specified pages. |
6
[Add Cover]
Press to add covers. |
7
[Transparency Cover Sheets]
Press to insert a sheet between each transparency when copying transparencies. You can also copy on the inserted sheets. |
8
[Original Type]
Press to select the type of original (text only, photo only, or both text and photo) you are going to copy. |
9
[Density]
Press to adjust the copy density. |
10
[Different Size Originals]
Press to make copies of different size originals by placing them as a group in the feeder. |
11
[N on 1]
Press to automatically reduce two, four, or eight page originals to fit onto a one-sided or two-sided copy sheet.
12
[Job Build]
This mode enables you to scan multiple originals that are too many to be placed at once, by dividing them into multiple batches.
1
[Secure Watermark]
Press to embed hidden text in the background of the print. The hidden text will become visible if the resulting output is copied. |
2
[Document Scan Lock]
Press to embed hidden information in copies. This increases security by preventing unauthorized copies. |
3
[Erase Frame]
Press to eliminate dark border areas, lines that appear around original images, or shadows from binding holes. |
4
[Sharpness]
Press to sharpen or soften the original image for the copy. |
5
[Gutter]
Press to create gutters along the sides of the copy. |
6
[Shift]
Press to shift the position of the original image for the copy. |
7
[Print Date]
This mode enables you to print the date. |
8
[Watermark]
This mode enables you to print a watermark. |
9
[Copy Set Numbering]
This mode enables you to print copy set numbers. |
10
[Page Numbering]
This mode enables you to print page numbers. |
1
[Print & Check]
Press to confirm scanned images page by page before copying when you scan originals on the platen glass. |
2
[Nega/Posi]
This mode enables you to copy the original image with the hues and gradations inverted. |
3
[Repeat Images]
This mode enables you to repeatedly copy the entire original image in either the vertical or horizontal direction. |
4
[Merge Job Blocks]
This mode enables you to scan multiple batches of originals with different copy settings and copy them as one document. |
5
[Cascade Copy]
This mode enables you to print copies from the machine and a cascade copy printer. |
6
[Superimpose Image]
Press to superimpose an image stored in memory onto the original image for copying. |
7
[Store in Mail Box]
This mode enables you to store originals scanned from the Copy screen as a file in a Mail Box. |
8
[Mirror Image]
Press to copy the original image reversed, as if it were a reflection in a mirror. |
9
[Job Done Notice]
Press to have the machine notify the user through e-mail when the copy job is done. |
You can perform the same operations on both the Regular Copy Basic Features screen and the Express Copy Basic Features screen. Set which screen to display from the Settings/Registration screen. (See "Switching the Copy Basic Features Screen.")
