Category
Top » Copy » Interrupt Mode
Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Store in Mail Box
Superimpose Image
Cascade Copy
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
Collapse all|Expand all
Interrupt Mode
The interrupt mode enables you to pause a reserved or current job to make higher priority copies. This mode is useful if you need to make a rush copy during a long copy job.
Press [Copy].
Press [Interrupt].
To change the Department ID before copying, press (Log In/Out) → enter the Department ID and PIN using - (numeric keys). (See "Entering the Department ID and PIN.")
Pressing [Interrupt] does not immediately stop the current job. Printing of the current job stops only when the actual printing of the priority or interrupt copy starts.
Set the desired copy modes.
4.
Press (Start).
If you want to continue making interrupt copies, wait until the current interrupt copy job is complete. Then, repeat steps 2 to 3.
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
You cannot make interrupt copies if there is an interrupt copy job being processed or waiting to be processed.
To cancel the Interrupt mode, press [Interrupt].
