Be sure to correctly set the paper type. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set for paper less than 16 lb bond (60 g/m2). Do not select the Finishing modes.
The paper used for the cover page must be the same size as that which is used for the main document.
Only 16 to 28 lb bond (60 to 105 g/m2) paper can be used for the main document.
Only paper whose weight is heavier than that used for the main document can be used for the cover paper.
[Saddle Fold] can only be set when two-sided copying is set.
The paper is saddle folded one sheet at a time, and then output.
You can only set [Rotate 90 Degrees] in the following cases:
If you select the available paper size manually
If the paper size compatible with Rotate 90 Degrees is loaded in both the horizontal and vertical directions
If [Paper Drawer Auto Selection On/Off] for the selected paper source is set to 'On' (See "Enabling Paper Drawer Auto Selection.")
If there is no paper which can be rotated, the output is collated.
Optional Unit
Collate
(Page order) |
Group
Offset
Rotate 90 Degrees
Staple
Hole Punch
Saddle Fold
Corner
Double
Saddle Stitch
None
Inner Finisher-D1
Inner 2Way Tray-H1
Inner Finisher-D1 and Inner 2/3 Hole Puncher-A1
Inner Finisher-D1 and Inner Finisher Additional Tray-A1
Inner Finisher-D1, Inner 2/3 Hole Puncher-A1 and Inner Finisher Additional Tray-A1
Staple Finisher-G1
Booklet Finisher-G1
Staple Finisher-G1 and External 2/3 Hole Puncher-B2
Booklet Finisher-G1 and External 2/3 Hole Puncher-B2
Paper Size
Corner
Double
11" x 17"
30 sheets
30 sheets
LGL
30 sheets
30 sheets
LTRR
30 sheets
30 sheets
LTR
50 sheets
50 sheets
EXEC
STMTR
STMT
Paper Size
Corner
Double
Saddle Stitch*1
11" x 17"
25 sheets
25 sheets
16 sheets
LGL
25 sheets
25 sheets
16 sheets
LTRR
25 sheets
25 sheets
16 sheets
LTR
50 sheets
50 sheets
EXEC
50 sheets
50 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
For information on optional products, see the following:
If [Finishing] is not set, sheets are output in the same way as when [Group (Same Pages)] is set.
If [Auto Collate] is set to 'On', the Collate or Offset Collate mode is automatically set when you place your originals in the feeder. (See "Enabling Auto Collating.")
You can display the detailed information of the selected paper by pressing
