(Start).|
To cancel scanning, press [Stop] or
(Stop). |
(Start).
(Start).|
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
If you place your originals in the feeder, remove the originals from the original output area when the scanning of each batch is complete.
You can change only those settings appearing in [Change Settings] while in the Job Build mode. You need to specify the necessary copy settings in advance. However, if you specify [N on 1] with the Job Build mode, you cannot change the settings for [Copy Ratio] or [Density].
If you want to place different size originals in the feeder, set [Different Size Originals]. (See "Different Size Originals.")
When you want to copy one-sided and two-sided originals as two-sided copies, set [1-Sided
2-Sided] if the first original is one-sided and set [2-Sided 2-Sided] if the first original is two-sided. Then manually set or cancel [2-Sided Original] for each batch of originals that you scan. |
