The cascade copy settings registered in [Favorite Settings] are changed to the local copy settings when the machine or the cascade copy printer is restarted. If you want to recall [Favorite Settings] and perform cascade copying, turn ON the main power of the printer → update the information for the cascade copy printer after the time set in [Startup Settings] has elapsed. (See "Cascade Copy Communication Timeout.")
The copy settings registered as [Favorite Settings] in memory are not deleted, even if you turn the main power OFF.
You can also store/edit favorite settings by pressing
→ [Register/Edit Favorite Settings]. |
