The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher is attached.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper or transparencies, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Make sure to place originals with a vertical (portrait) orientation vertically. If these originals are placed horizontally, the even numbered pages will be printed upside down.
The Finishing modes cannot be set for paper less than 16 lb bond (60 g/m2). Do not select the Finishing modes.
You cannot select the type of two-sided original if you do not use the Booklet Scan mode.
The maximum number of sheets that can be saddle stitched at one time is 16. If you want to saddle stitch 17 or more sheets, set the Divided Booklet mode.
If the number of sheets is 17 or more, the booklet is not saddle stitched.
If you select [Fold Only], only one sheet can be folded at one time.
You must select the same paper size for the cover page as that used for the main document.
If you are using Heavy 3 or Heavy 4 paper, you can only print on <Front Inside Cover> or <Back Inside Cover>.
Only 17 to 28 lb bond (60 to 105 g/m2) paper can be used for the main document.
Use heavier paper than the main document for the cover page.
The number of saddle stitched booklets that the booklet tray can hold depends on the number of sheets that each booklet contains.
to adjust the correction width.|
If you set [Auto] for [Creep Correction] and perform cascade copying, the creep correction values set in each machine are applied. Set the same creep correction for the machine and cascade copy printer.
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
11" x 17"/LGL
LTRR
Make sure to set the Booklet Tray guide to match the paper size. Setting the Booklet Tray guide incorrectly may result in a paper jam.
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
