Category
Top » Copy » Print & Check
Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Store in Mail Box
Superimpose Image
Cascade Copy
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
Collapse all|Expand all
Print & Check
This enables you to confirm scanned images page by page when you scan originals in succession on the platen glass. This is useful to prevent miscopying resulting from misscanning.
Place your original on the platen glass. You cannot copy using [Print & Check] with the originals set in the feeder.
Press [Copy].
Press [Options] → [Print & Check] → [Close].
Press (Start).
Check the content of the output.
To copy the next original, place your original → press (Start)again.
To rescan an original immediately after scanning, reset the original → select [Re-Scan] → press (Start).
If you want to change the scan settings, press [Change Settings]. If you want to change the settings, change them before pressing (Start).
Scan the originals until they are all scanned. Press [Start Copying] to start copying.
To cancel scanning, press [Stop] or (Stop).
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
When [1-Sided2-Sided] is set, two-sided copying is not performed and the machine copies one original at a time.
