Category
Top » Copy » Gutter Mode
Category Top
Overview of This Function
Flow of Copy Operations
Canceling a Copy Job
Reserved Copying
Copy Sample
Recalling Previous Copy Jobs (Previous Settings)
Storing, Recalling, and Deleting Favorite Settings (Favorite Settings)
Storing Favorite Settings
Recalling and Deleting Favorite Settings
Assigning Shortcuts
Changing and Canceling Copy Settings
Interrupt Mode
Changing Basic Copy Ratios
Zoom by Length
Setting the X and Y Axes Independently
Paper Selection
Book→2 Pages
Two-Sided Copying
Collating Copies
Booklet Mode
Job Build
N on 1
Add Cover
Inserting Sheets
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Inserting Sheets When Copying Onto Transparencies
Adding a Secure Watermark
Document Scan Lock
Page Numbering
Copy Set Numbering
Adjusting the Image Sharpness
Erase Frame
Watermark Printing
Date Printing
Shifting the Original Image
Gutter Mode
Print & Check
Inverting Images (Nega/Posi)
Repeat Images
Merge Job Blocks
Job Done Notice
Mirror Image
Store in Mail Box
Superimpose Image
Cascade Copy
Various Features of the Express Copy Basic Features Screen
Operating the Express Copy Basic Features Screen
Setting Shortcuts on the Express Copy Basic Features Screen
Appendix
Collapse all|Expand all
Gutter Mode
This mode enables you to shift the image to the left, right, top, or bottom in order to create a gutter on the copies. Use this mode to make copies or prints ready for placement in ring binders.
Select the gutter position according to the binding direction.
Left Margin Selected
Right Margin Selected
Top Margin Selected
Bottom Margin Selected
Press [Copy].
Press [Options] → [Gutter].
Select the gutter position.
4.
Press [Front Side] or [Back Side] → press [-] or [+] to set their respective gutter width → press [OK].
If you are using [Gutter] and [2-Sided] together and copying a document that lacks a gutter, follow the instructions below:
If there is a gutter:
1-Sided2-Sided: Set the Gutter mode for the back side only.
2-Sided2-Sided: You do not need to set the Gutter mode.
2-Sided1-Sided: Set the Gutter mode for the back side only.
If there is no gutter:
1-Sided2-Sided: Set the Gutter mode for both the front side and back side.
2-Sided2-Sided: Set the Gutter mode for both the front side and back side.
2-Sided1-Sided: Set the Gutter mode for both the front side and back side.
If you enter a value other than 0, you can switch between positive and negative gutter width by pressing [±].
Examples:
(+) 10 → [±] → - 10
- 50 → [±] → (+) 50
5.
Press [Close].
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
[Gutter] shifts the entire original image by the designated width. Therefore, an original whose image extends all the way to the edges of the sheet may be partially cut off on the copy.
You can choose to only create a gutter on the back side of a copy. This enables you to copy originals that already have a gutter in the 1-Sided2-Sided mode or 2-Sided1-Sided mode.
