Prevents dark background color from being copied, but light areas on the original may not be copied either.
You may not be able to completely prevent dark background color from being copied, but light areas on the original are always copied.
For information on the modes which cannot be set in combination with this mode, see "Combination of Functions Chart."
If you adjust the background density by pressing [Adjust] for <Background Density>, the [Auto] setting is canceled. Similarly, if you press [Auto] while making manual adjustments in [Adjust], your adjustments are canceled. The machine automatically adjusts the density to match the background.
If you select [Auto] for Background Density, [Text] is automatically set for [Original Type].
